Cannot ping from one network to another when using two switches
undercloud
I am trying to ping from network 192.168.0.0 to network 172.162.0.0 with no success. It relates to an exercise, for a back-up network connection. does anyone have any idea why I can't ping from one network to another? Thank you
PC1: Network 192.168.0.0 vlan 10
interface FastEthernet0/1
switch port access vlan 10
interface Gigabit Ethernet0/1
switch port trunk allowed vlan 10
switch port mode trunk
interface Gigabit Ethernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.0.1 255.255.255.0
PC2: Network 172.162.0.0 vlan 20
switchport access vlan 20
interface GigabitEthernet0/1
switchport trunk allowed vlan 20
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan20
ip address 172.162.0.1 255.255.0.0
2 Accepted Solutions
then put all devices in the 10.0.0.0/8 network and on the same vlan.  Anytime you have different vlans and/or different networks, you must have L3 device to do routing between them.  Note: usually same vlan = same network, aka network/subnet x is on vlan x; subnet y is on vlan y.
Regards, ML
**Please Rate All Helpful Responses **
I run lab using the SW model you mention and as @Martin L  suggest before you need to change the SW this SW not support L3 (can not config ip routing on it) and this cut the inter-vlan.
so lab can not done as you like with this SW.
17 Replies 17
Hello
Make sure you created the vlans on the switches. Use the command
switch4
conf t
vlan 10
and on the switch 3
conf t
vlan 20
Also make sure the PC has gateway configured on it.
Hello, i changed some settings and both networks can ping to their gateway, but I have not yet managed to ping from one network to the other one, even with adding the vlans.
switchport access vlan 10
switchport trunk allowed vlan 10,20
interface Vlan1
no ip address
shutdown
interface Vlan10
interface Vlan20
interface Vlan1
no ip address
shutdown
interface Vlan10
interface Vlan20
In order  tp ping between network you need to enable routing by using the command
conf t
ip routing
 If you are using a Layer 2 switch , you need to replace to a Layer3 switch.
As per your config, you are using the same IP address on both sides, which is also wrong.  If you used .1 in one side, you need to use another IP on the other side.
But, on this case either you use a Layer3 switch or a Router.
Add vlan 10 and vlan 20 to both switch
Then allow both vlan in trunk connect two sw' I see you allow only one in each side
interface Vlan1
no ip address
shutdown
interface Vlan10
interface Vlan20
interface Vlan1
no ip address
shutdown
interface Vlan10
interface Vlan20
The SVI of vlan have same IP in both SW'
That wrong you need diff IP for SVI in each SW.
Martin L
you can attach your PT file here but it must be in zip format
Regards, ML
I send it, thanks a lot.
Martin L
Those are L2 switches; you need L3 switches in order to ping between different networks or router (or router on a-stick).  Just replace your switches with c3560 or c3650 and copy config. Note that one of those models has no ip routing set; just enable it with ip routing command.
Regards, ML
the problem is i am not allowed to use any switch other than the 2960 as i have an exercise on this.
Interesting..... what are other restrictions ?  I think ,in that case, they have to be on the same network, like 10.0.0.0/8. I mean PC and Server have to be on the same network and if you want to ping switches, add IPs to SVI and those must be on the same network as well (different IPs)
Regards, ML
only two restrictions is that i have to use network 10.0.0.0 and use two 2960 switch. And that PC can ping up to the server and vice versa. Is there any way to give me the settings I should use? thanks in advance
Regards, ML
