Cant Ssh to CISCO 2911 from outside
J32773277
Hello Dears,
I am facing a strange issue with my Voice gateway router,
 I can access it  from a local network of  site using SSH and the credentials to log in.but I Cant access same from other site with same credentials ,the running config as below:
login as:admin
Using keyboard-interactive authentication.
Password:
GW>en
Password:
GW#sh run
Building configuration...
Current configuration : 4447 bytes
version 15.5
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname GW
boot-start-marker
boot system flash c2900-universalk9-mz.SPA.155-1.T.bin
boot-end-marker
enable secret 5 ******************************
no aaa new-model
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
clock timezone GMT 0 0
clock summer-time BST recurring last Sun Mar 0:00 last Sun Oct 0:00
no ip domain lookup
ip domain name das.cisco.com
ip cef
no ipv6 cef
cts logging verbose
voice-card 0
voice service voip
 ip address trusted list
  ipv4 10.x.x.x.
  ipv4 10.x.x.x.
  ipv4 10.x.x.x.
  ipv4 10.x.x.x.
 address-hiding
 mode border-element
 allow-connections sip to sip
 redirect ip2ip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  midcall-signaling passthru
voice class codec 10
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729r8
license udi pid CISCO2911/K9 sn FCZ153870BM
license accept end user agreement
hw-module pvdm 0/0
username admin password 7 **********
redundancy
no cdp run
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
translation-rule 10
 Rule 0 ^90 0
 Rule 1 ^91 1
 Rule 2 ^92 2
 Rule 3 ^93 3
 Rule 4 ^94 4
 Rule 5 ^95 5
 Rule 6 ^96 6
 Rule 7 ^97 7
 Rule 8 ^98 8
 Rule 9 ^99 9
translation-rule 40
 Rule 0 ^1 093231
 Rule 1 ^2 093232
 Rule 2 ^3 093443
 Rule 3 ^4 093444
 Rule 4 ^5 093445
 Rule 5 ^6 093446
 Rule 6 ^7 093447
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 10.xx.x.x. 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 description ### link for SIP Trunk ###
 ip address 1x2.x.x.x. 255.255.255.0
 ip access-group 100 in
 duplex full
 speed 100
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 10.x.0.0 255.255.0.0 10.x.2.1
ip route ********* 255.255.255.0 GigabitEthernet0/2 1x2.x.x.x
access-list 100 permit ip host ********** host 1x2.x.x.x
access-list 100 permit ip host *********** host 1x2.x.x.x
access-list 100 permit ip host ********* host 1x2.x.x.x
access-list 100 permit ip host ******** host 1x2.x.x.x
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1000 voip
 description ### Trunk DP ###
 translation-profile incoming SIPInbound
 huntstop
 destination-pattern 9T
 translate-outgoing calling 40
 translate-outgoing called 10
 rtp payload-type cisco-codec-fax-ind 98
 no modem passthrough
 session protocol sipv2
 session target ipv4:178.250.112.66
 voice-class codec 10
 voice-class sip dtmf-relay force rtp-nte
 voice-class sip options-ping 65
 dtmf-relay rtp-nte
 fax-relay sg3-to-g3
 fax rate 14400
dial-peer voice 1100 voip
 description ### Airspeed SIP Trunk DP ###
 session target ipv4:10.107.2.4
 incoming called-number 9T
 dtmf-relay rtp-nte
 fax-relay sg3-to-g3
 fax rate 14400
dial-peer voice 1101 voip
 session target ipv4:1x2.x.x.x
 dtmf-relay rtp-nte
 fax-relay sg3-to-g3
 fax rate 14400
sip-ua
 keepalive target ipv4:1x2.x.x.x
gatekeeper
 shutdown
line con 0
 logging synchronous
 login local
line aux 0
 logging synchronous
 login local
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 logging synchronous
 login local
 transport input ssh
line vty 5 15
 logging synchronous
 login local
 transport input ssh
scheduler allocate 20000 1000
end
GW#
Please help me!! :)
6 Replies 6
d-fillmore
Level 2
Level 2
Could there be a firewall somewhere in between blocking the SSH?
Can you ping the management address from the other site?
There is no firewalls,Yes I can ping and even its asking for credentials while am asking,but if I enter password it fails.
I can see the other device in that site using aes256-cbc encryption.
SW#sh ssh
%No SSHv1 server connections running.
Connection Version Mode Encryption  Hmac         State                 Username
0          2.0     IN   aes256-cbc  hmac-sha1    Session started       admin
0          2.0     OUT  aes256-cbc  hmac-sha1    Session started       admin
But the new device are 15.5 IOS and uses aes128-cbc encryption
GW#sh ssh
0          2.0     IN   aes128-cbc  hmac-sha1    Session started       admin
0          2.0     OUT  aes128-cbc  hmac-sha1    Session started       admin
Does it cause any problem,However the local access is there.??
Not sure, Try 'debug ip ssh detail' on the GW device and see if it's reporting any errors.
What are you trying to ssh from? - is it another cisco device or a machine using putty/securecrt?
The device is in another country.. they can ssh into device locally,but I cant access.
Andre Neethling
Level 4
Level 4
Check access list 100 and make sure that the uo you are trying to connect from and the protocol you are using is allowed in that access list.
There is no ACL configured in the router,The g/w have below ACLs
L3#sh access-lists
Extended IP access list system-cpp-all-routers-on-subnet
    10 permit ip any host 224.0.0.2
Extended IP access list system-cpp-all-systems-on-subnet
    10 permit ip any host 224.0.0.1
Extended IP access list system-cpp-dhcp-cs
    10 permit udp any eq bootpc any eq bootps
Extended IP access list system-cpp-dhcp-sc
    10 permit udp any eq bootps any eq bootpc
Extended IP access list system-cpp-dhcp-ss
    10 permit udp any eq bootps any eq bootps
Extended IP access list system-cpp-energywise-disc
    10 permit udp any eq any eq 0
Extended IP access list system-cpp-hsrpv2
    10 permit udp any host 224.0.0.102
Extended IP access list system-cpp-igmp
    10 permit igmp any 224.0.0.0 31.255.255.255
Extended IP access list system-cpp-ip-mcast-linklocal
    10 permit ip any 224.0.0.0 0.0.0.255
Extended IP access list system-cpp-ospf
    10 permit ospf any 224.0.0.0 0.0.0.255
Extended IP access list system-cpp-pim
    10 permit pim any 224.0.0.0 0.0.0.255
Extended IP access list system-cpp-ripv2
    10 permit ip any host 224.0.0.9
Extended MAC access list system-cpp-bpdu-range
    permit any 0180.c200.0000 0000.0000.0003
Extended MAC access list system-cpp-cdp
    permit any host 0100.0ccc.cccc
Extended MAC access list system-cpp-dot1x
    permit any host 0180.c200.0003
Extended MAC access list system-cpp-sstp
    permit any host 0100.0ccc.cccd
L3#exi
