11-14-2016 05:04 AM - edited 03-08-2019 08:09 AM
Hi All,
Can I use the Call Home feature so that if either of the devices were to "crash", the crashinfo files could be automatically uploaded to an external destination?
If not, could EEM perform the same task?
Thanks in advance.
11-14-2016 06:28 AM
Here is a document on smart call home for the 6800 series.
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/smart_call_home/QuickStart_6800.pdf
11-14-2016 07:05 AM
Paul
Sure, you can use Smart Call Home for this specific purpose. In addition, SCH may also be used to alert about diagnostic findings, Environmental changes and such. Take a look at the document titled Smart Call Home Feature Guide. It is detailed and exhaustive and helpful.
Let us know if you have any follow up questions OR clarifications.
Kind regards .... Palani
