Join Customer Connection to register!
572
gemini1133
Beginner
cat6 cable problem cisco sr2024
i have two switch cisco sr2024 when connect two swithch with cable cat6 can not see the others
when connect cat 5 can see the other
i change cable cat6 to another cable cat6 new type problem the same
1 REPLY 1
Reza Sharifi
Hall of Fame Expert
Hi Ameer,
It should work just fine with cat 5 or 6.
From the datasheet:
Cabling type
Category 5 Ethernet or better
Here is the datasheet:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps10007/ps10015/data_sheet_c78-500638.pdf
Reza
