02-28-2022 08:08 AM
How do I identify the frames/packets being dropped due to no adjacency?
Branch site having problems. I engaged TAC on this but no solution. With built in Wireshark and other advanced capabilities, hoped we could identify which traffic the Cat9300 is refusing to forward across a point to point link.
Keeps incrementing:
sh ip traffic | in adj
Drop: 0 encapsulation failed, 0 unresolved, 1621097 no adjacency
Need to identify this traffic to rule it out as a potential cause of the performance. Bandwidth and ping times are excellent.
100Mb/s connection highest seen is 15Mb/s. Ping times are 18ms consistently to hub.
02-28-2022 08:13 AM
Post complete output :
Also provide how is this network connected ? wht is the other side connected ?
Hum means VPN ?
02-28-2022 08:15 AM - edited 02-28-2022 08:20 AM
sh ip traffic
IP statistics:
Rcvd: 3104 total, 115883 local destination
0 format errors, 0 checksum errors, 0 bad hop count
0 unknown protocol, 0 not a gateway
0 security failures, 0 bad options, 205 with options
Opts: 0 end, 0 nop, 0 basic security, 0 loose source route
0 timestamp, 0 extended security, 0 record route
0 stream ID, 0 strict source route, 205 alert, 0 cipso, 0 ump
0 other, 0 ignored
Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
0 fragmented, 0 fragments, 0 couldn't fragment
0 invalid hole
Bcast: 1414 received, 20 sent
Mcast: 35182 received, 52915 sent
Sent: 154218 generated, 15953963 forwarded
Drop: 0 encapsulation failed, 0 unresolved, 1638796 no adjacency
0 no route, 0 unicast RPF, 0 forced drop, 0 unsupported-addr
0 options denied, 0 source IP address zero
ICMP statistics:
Rcvd: 0 format errors, 0 checksum errors, 0 redirects, 0 unreachable
690 echo, 1000 echo reply, 0 mask requests, 0 mask replies, 0 quench
0 parameter, 0 timestamp, 0 timestamp replies, 0 info request, 0 other
0 irdp solicitations, 0 irdp advertisements
0 time exceeded, 0 info replies
Sent: 0 redirects, 0 unreachable, 1000 echo, 690 echo reply
0 mask requests, 0 mask replies, 0 quench, 0 timestamp, 0 timestamp replies
0 info reply, 3 time exceeded, 0 parameter problem
UDP statistics:
Rcvd: 88627 total, 0 checksum errors, 1360 no port 0 finput
Sent: 87309 total, 0 forwarded broadcasts
OSPF statistics:
Last clearing of OSPF traffic counters 22:40:03
Rcvd: 0 total, 0 checksum errors
0 hello, 0 database desc, 0 link state req
0 link state updates, 0 link state acks
Sent: 0 total
PIMv2 statistics: Sent/Received
Total: 0/0, 0 checksum errors, 0 format errors
Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0, Hellos: 0/0
Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0
Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
Queue drops: 0
State-Refresh: 0/0
IGMP statistics: Sent/Received
Total: 0/0, Format errors: 0/0, Checksum errors: 0/0
Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0
DVMRP: 0/0, PIM: 0/0
Queue drops: 0
Report VRF mismatch drops: 0
TCP statistics:
Rcvd: 7975 total, 0 checksum errors, 16 no port
Sent: 12301 total
BGP statistics:
Rcvd: 0 total, 0 opens, 0 notifications, 0 updates
0 keepalives, 0 route-refresh, 0 unrecognized
Sent: 0 total, 0 opens, 0 notifications, 0 updates
EIGRP-IPv4 statistics:
Rcvd: 17591 total
Sent: 52915 total
ARP statistics:
Rcvd: 36349 requests, 1407 replies, 0 reverse, 0 other
Sent: 8124 requests, 13096 replies (0 proxy), 0 reverse
Drop due to input queue full: 0
s-uhh-plat-1#
02-28-2022 08:30 AM
no vpn. point to point /30. fiber via service provider in different cities. Routed ports on each switch. EIGRP.
02-28-2022 08:34 AM - edited 02-28-2022 08:55 AM
show adjacency summary
Adjacency table has 32 adjacencies:
each adjacency consumes 548 bytes (72 bytes platform extension)
32 complete adjacencies
0 incomplete adjacencies
32 adjacencies of linktype IP
32 complete adjacencies of linktype IP
0 incomplete adjacencies of linktype IP
0 adjacencies with fixups of linktype IP
30 adjacencies with IP redirect of linktype IP
0 adjacencies post encap punt capable of linktype IP
Adjacency database high availability:
Database epoch: 0 (32 entries at this epoch)
RP adjacency component enabled
Adjacency manager summary event processing:
Summary events epoch is 1
Summary events queue contains 0 events (high water mark 2 events)
