Join Customer Connection to register!
348
Highlighted
Beginner
Catalyst 1000 simple ip management mode LAG with two nodes.
I use SG500 in stack mode with agregation for host servers between two nodes switches. Working fine. Do you know if this topology of LAG is supported on Catalyst 1000 cluster ?
4 REPLIES 4
Highlighted
Hall of Fame Expert
Can you post your config? For LAG, you need a minimum of 2 1Gig or 10Gig interfaces in a bundle. You can use mode "On" LACP.
Highlighted
I don’t have any config. I just want to know if Catalyst 1000 in stack mode support full mesh LAG like SG500 or SG350x stack.
Highlighted
Should not be an issue as both platforms support LAG.
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350xg/admin_guide/AG_Tesla_350_550.pdf
Highlighted
Actually We use this configuration on SG500 stack and works very good. We just want to know of this setup is supported on Catalyst 1000.
Content for Community-Ad
