12-20-2010 04:35 AM - edited 03-06-2019 02:37 PM
My network is composed by 12 Cisco 2950 in 3 different buildings.
We have about 100 computers always connected, with a maximum of 250 simultaneous computer connected.
We have latency problem, visibly broadcast frame is responsible of this problem.
We use DHCP so we can’t use storm-control broadcast.
Can we use storm-control for all ports except the 67 (BOOTP) and 68, to use a limitation for all non DHCP broadcast?
The aim is to keep only the BOOTP frame in broadcast. We can keep a very few other broadcast frame.
We don’t configure computer, each people configure is computer, so we have to do this in the switch.
Thanks you.
12-20-2010 07:42 AM
No, Storm control is a layer 2 security feature.
But there is other solution to mitigate broadcasts impact such as VLANs, static arp cache,stop using NETBIOS if possible.
I don't think DHCP is the culprit.
Regards.
Alain.
12-20-2010 11:43 PM
Thanks you.
I don’t think DHCP is the culprit but if we can restrain the number of broadcast, DHCP request will be affect by this restriction. So the idea is to restrain all of broadcast frame except DHCP frame.
We can’t use VLANs because, all computers have to communicate each other. We have multiple Internet access sharing and we use pear to pear software to exchange data. Do you know a solution to continue to see each other in different VLAN, a think like VLAN friend.
Have you more information about ARP cache, on this switch?
Thanks.
David
12-21-2010 12:21 AM
To communicate between VLANs you must do intervlan routing with a router( router on a stick) or with a L3 switch( using SVIs).
When I was talking about arp cache it was on the hosts.
Have you done a survey to know your traffic and correlate this latency with some broadcast traffic?
Regards.
Alain.
