catalyst 2950 - reset password
realiswitch
hi everybody
i forgot password o my cisco catalyst 2950 switch
do you know how can i reset it?
thanks!
7 Replies 7
ankbhasi
mohammedmahmoud
Level 11
Level 11
Pavel Bykov
Level 5
Level 5
You will need physical access to the switch.
thanks, it's ok
i followed the steps and i reset the password...
THANKS A LOT!!
Now....may you tell me how can i reset cfg of my 2950?
You should follow the document link sent by mohammedmahmoud it will take you through all the required steps to restore previous configuration and change the passwords.
But If you want to erase the current config and re-start everything from scratch, then in type in the following command
Switch#erase nvram:
and that reload the switch
Shaheen
Just use "write erase " then reload the box .
what about the vlan.dat? :)
