08-06-2019 08:55 AM
I'm French and sorry for my bad English ;)
We are now supervising infrastructure for our new customer, which is composed by :
- 1 master switch with a DHCP, 3 VLAN (Catalyst 2960)
- 2 secondary switch without any function (Zyxel)
Our customer has some problem to get an IP from DHCP: There's 10 excluded address for the printers, and all the rest is reachable. By the way, for an unknown reason, the pool only lease a few IPs (a dozen), and exclude the others until .255
Pool 2nd :
Utilization mark (high/low) : 100 / 0
Subnet size (first/next) : 0 / 0
Total addresses : 254
Leased addresses : 20
Excluded addresses : 155
Remembered addresses : 0
Pending event : none
1 subnet is currently in the pool :
Current index IP address range Leased/Excluded/Total
10.241.131.1 10.241.131.1 - 10.241.131.254 20 / 155 / 254
In the ARP table, some addresses have the same MAC :
Internet 10.241.131.41 4 847b.eb43.9080 ARPA Vlan71
Internet 10.241.131.42 29 2c30.33e6.0c3a ARPA Vlan71
Internet 10.241.131.43 4 241c.0408.aaf6 ARPA Vlan71
Internet 10.241.131.44 3 847b.eb43.9080 ARPA Vlan71
Internet 10.241.131.45 3 241c.0408.aaf6 ARPA Vlan71
Internet 10.241.131.46 3 847b.eb43.9080 ARPA Vlan71
Internet 10.241.131.47 3 241c.0408.aaf6 ARPA Vlan71
Internet 10.241.131.48 3 847b.eb43.9080 ARPA Vlan71
Internet 10.241.131.49 3 241c.0408.aaf6 ARPA Vlan71
Internet 10.241.131.50 3 847b.eb43.9080 ARPA Vlan71
Internet 10.241.131.51 3 241c.0408.aaf6 ARPA Vlan71
Internet 10.241.131.52 2 241c.0408.aaf6 ARPA Vlan71
Internet 10.241.131.53 2 847b.eb43.9080 ARPA Vlan71
Internet 10.241.131.54 2 847b.eb43.9080 ARPA Vlan71
Internet 10.241.131.55 2 241c.0408.aaf6 ARPA Vlan71
Internet 10.241.131.56 2 847b.eb43.9080 ARPA Vlan71
Internet 10.241.131.57 2 241c.0408.aaf6 ARPA Vlan71
Internet 10.241.131.58 0 7085.c212.880b ARPA Vlan71
Internet 10.241.131.59 2 847b.eb43.9080 ARPA Vlan71
Internet 10.241.131.60 1 241c.0408.aaf6 ARPA Vlan71
Internet 10.241.131.61 1 847b.eb43.9080 ARPA Vlan71
Internet 10.241.131.63 1 847b.eb43.9080 ARPA Vlan71
Internet 10.241.131.64 1 847b.eb43.9080 ARPA Vlan71
I tried a clear ip binding, clear ip conflicts *, clear arp, clear arp-cache, clear ip arp interface vlan 71 but no effects, the DHCP don't lease addresses. The switch is up-to-date, and the problem still here. We are far from the client, and we can't shut down the DHCP pool to recreate it (we can't stop the production).
If someone has an idea or a solution, I'm interested :)
Thanks to all.
08-06-2019 09:02 AM
Can you post show version, and full show run to look what you configured.
08-06-2019 09:12 AM
Version :
cisco WS-C2960X-48TS-L (APM86XXX) processor (revision M0) with 524288K bytes of memory.
Processor board ID FCW2046B77T
Last reset from reload command
8 Virtual Ethernet interfaces
1 FastEthernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 08:CC:A7:82:83:80
Motherboard assembly number : 73-16693-05
Power supply part number : 341-0537-02
Motherboard serial number : FOC204647NK
Power supply serial number : LIT20412D9L
Model revision number : M0
Motherboard revision number : A0
Model number : WS-C2960X-48TS-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC20465L37
System serial number : FCW2046B77T
Top Assembly Part Number : 68-100471-02
Top Assembly Revision Number : A0
Version ID : V05
CLEI Code Number : CMMNF00ARD
Daughterboard revision number : A0
Hardware Board Revision Number : 0x19
Switch Ports Model SW Version SW Image
* 1 52 WS-C2960X-48TS-L 15.2(4)E8 C2960X-UNIVERSALK9-M
Configuration register is 0xF
Run :
Current configuration : 7016 bytes
! Last configuration change at 13:24:26 UTC Tue Aug 6 2019
version 15.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
enable secret 5
no aaa new-model
clock timezone UTC 1 0
switch 1 provision ws-c2960x-48ts-l
ip routing
no ip cef optimize neighbor resolution
no ip dhcp conflict logging
ip dhcp excluded-address 10.241.127.1 10.241.127.10
ip dhcp excluded-address 10.241.131.1 10.241.131.10
ip dhcp excluded-address 10.251.2.1 10.251.2.32
ip dhcp excluded-address 10.251.251.1 10.251.251.10
ip dhcp excluded-address 10.251.131.1 10.251.131.10
ip dhcp excluded-address 10.251.127.1 10.251.127.10
no ip dhcp ping packets
ip dhcp pool 1st
network 10.241.127.0 255.255.255.0
default-router 10.241.127.1
domain-name **
dns-server 10.251.2.2 10.251.2.3
ip dhcp pool Srv
network 10.251.2.0 255.255.255.0
default-router 10.251.2.1
domain-name **
ip dhcp pool fwi
network 10.251.251.0 255.255.255.128
default-router 10.251.251.2
domain-name **
dns-server 8.8.8.8 8.8.4.4
ip dhcp pool 2nd
network 10.241.131.0 255.255.255.0
default-router 10.241.131.1
domain-name **
lease 0 8
ip dhcp pool Demo
network 10.241.191.0 255.255.255.0
crypto pki trustpoint TP-self-signed-**
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-**
revocation-check none
rsakeypair TP-self-signed-**
crypto pki certificate chain TP-self-signed-**
certificate self-signed 01
quit
spanning-tree mode pvst
errdisable recovery cause loopback
vlan internal allocation policy ascending
interface Port-channel1
switchport access vlan 101
switchport mode access
interface FastEthernet0
no ip address
no ip route-cache
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
channel-protocol lacp
channel-group 1 mode active
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
switchport access vlan 161
interface GigabitEthernet1/0/24
switchport access vlan 191
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
switchport access vlan 41
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
switchport access vlan 71
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
ip address 10.251.1.1 255.255.255.0
interface Vlan41
ip address 10.241.127.1 255.255.255.0
interface Vlan71
ip address 10.241.131.1 255.255.255.0
interface Vlan101
ip address 10.251.2.1 255.255.255.0
interface Vlan131
ip address 10.251.131.2 255.255.255.0
interface Vlan161
ip address 10.251.251.1 255.255.255.128
interface Vlan162
ip address 10.251.251.134 255.255.255.128
interface Vlan191
ip address 10.241.191.1 255.255.255.0
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.251.251.2 permanent
ip route 10.241.131.0 255.255.255.0 Vlan71
ip route 10.251.2.0 255.255.255.0 Vlan101
ip route 10.251.251.0 255.255.255.128 Vlan161
line con 0
line vty 0 4
password **
login
line vty 5 15
password **
login
end
Here you got, thanks !
08-06-2019 02:25 PM - edited 08-06-2019 02:41 PM
Hello
Suggest the following and test again:
conf t
no ip route 10.241.131.0 255.255.255.0 Vlan71
no ip route 10.251.2.0 255.255.255.0 Vlan101
no ip route 10.251.251.0 255.255.255.128 Vlan161
ip dhcp ping packets 2 <--- validation check before dhcp allocates
Can you also confirm whats connecting to the port-channel 1 on vlan 101
