Catalyst 2960
I have Catalyst 2960 and trying to access the web console. Below is what the page shows. If I click on the web console I am getting an error saying http 404 not found. Any ideals what to try to get this to work?
Cisco Systems
Accessing Cisco WS-C2960-48TT-L "Switch"
Telnet - to the router.
Show interfaces - display the status of the interfaces.
Show diagnostic log - display the diagnostic log.
Monitor the router - HTML access to the command line interface at level 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
Show tech-support - display information commonly needed by tech support.
Extended Ping - Send extended ping commands.
Web Console - Manage the Switch through the web interface.
Help resources
  1. CCO at www.cisco.com - Cisco Connection Online, including the Technical Assistance Center (TAC).
  2. tac@cisco.com - e-mail the TAC.
  3. 1-800-553-2447 or +1-408-526-7209 - phone the TAC.
  4. cs-html@cisco.com - e-mail the HTML interface development group.
6 Replies 6
Leo Laohoo
Post the complete output to the CLI command of "dir".
Hopefully this is what you was asking. I not good with Cisco switches or any thing so if this is not what you wanted let me know please. Thanks.
------------------ show flash: ------------------
Directory of flash:/
    2  -rwx        1048   Mar 1 1993 00:01:00 +00:00  multiple-fs
    3  -rwx     8471143  Feb 27 2013 00:42:17 +00:00  c2960-lanbasek9-mz.122-52.SE.bin
    5  -rwx     5709294  Oct 19 2007 03:51:55 +00:00  c2960-lanbasek9-mz.122-35.SE1.bin
32514048 bytes total (18330624 bytes free)
Ok, the error message makes sense because there is no HTML pages in the flash directory.
If GUI is required then the complete TAR file will need to be unpacked into the switch.  The TAR file has the complete set of HTML files needed for GUI.
So what file do I need to download? And is this very hard to upload it to the switch? Reason I am trying to use the web version is because I don't know the commands and all that to do this using telnet or other utilities. Would this be the file LAN BASE WITH WEB BASED DEV MGR
c2960-lanbasek9-tar.122-52.SE.tar ?
Download the file "c2960-lanbasek9-tar.122-55.SE10.tar".  Use this version as it is very stable.
The CLI command is:  archive download-sw tftp://<TFTP IP address>/c2960-lanbasek9-tar.122-55.SE10.tar
Where I can get the c2960-lanbasek9-tar.122-52.SE.tar file?
