05-24-2010 12:56 PM - edited 03-06-2019 11:14 AM
Hi everybody.
I'm very new to Cisco. And now I need to set up some configuration urgently. I know that I should to read lot of manuals rather than to annoy this community with stupid questions. But it looks like I will not have time for experiments if the problem will not be solved tomorrow... :-(
So, I have Catalyst 3560G. I do not know is it V1 or V2 and I don't know how to find it out.
There are 10 computers connected directly to it, all in 192.168.0.x, and one port from another net, 10.0.0.x. I need to set routing between theese networks. It doesn't work. Pings do not pass between.
I'm configuring Catalyst using Cisco Network Assistant and web interface. Have read about CLI but didn't try it yet.
I did reset all settings to factory defaults and tried to configure all things from scratch but did not succeed.
Help me please. If this will be done I will have time to read Cisco manuals...
Solved! Go to Solution.
05-24-2010 01:06 PM
mannie.ney wrote:
Hi everybody.
Mannie
From the CLI
3560(config)# ip routing
3560(config)# vlan 10 name v10
3560(config)# vlan 11 name v11
3560(config)# int vlan 10
3560(config-if)# ip address 192.168.0.x 255.255.255.0 <-- where .x is a spare address from the 192.168.0.x network
3560(config)# int vlan 11
3560(config-if)# ip address 10.0.0.x 255.255.255.0 <-- where .x is a spare address from the 10.0.0.x network
set the default-gateway for computers in 192.168.0.x network to be the IP address you have configured under vlan 10.
set the default-gateway for the computer in the 10.0.0.x network to the IP of vlan 11.
Allocate the ports into the right vlans ie. for each port connected to a 192.168.0.x computer -
int gi0/2
switchport mode access
switchport access vlan 10
etc..
Jon
05-24-2010 11:13 PM
Hi everybody.
Check out the below link for step bt step configuration of vlan and intervlan routing in 3560 switches,hope to help !!
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008015f17a.shtml
http://www.cisco.com/public/technotes/smbsa/en/us/lan/config_inter_vlan_routing_oncatswtch.pdf
Remember to rate the helpful post
Ganesh.H
05-24-2010 01:06 PM
mannie.ney wrote:
Hi everybody.
Mannie
From the CLI
int gi0/2
etc..
Jon
05-25-2010 04:28 PM
THANK YOU! Everything is OK now :-)
05-24-2010 11:13 PM
Hi everybody.
Ganesh.H
05-25-2010 04:31 PM
Thank you too for perfect docs :-)
