Catalyst 3560x gui interface
quasardan
if a connect to the switch via Internet Explorer or every other browser I can't enter configuration because I receive a screen as you can view in image below.
And I can view those errors:
message: 're_preFlt_txt33' is not defined
Linea: 31
Carattere: 1
Codice: 0
URI:
http://10.2.2.28/setup_report.htm
message: 're_preFlt_txt25' is not defined
Linea: 67
Carattere: 1
Codice: 0
URI:
message: 're_preFlt_txt53' is not defined
Linea: 72
Carattere: 11
Codice: 0
URI:
message: 're_preFlt_txt20' is not defined
Linea: 114
Carattere: 1
Codice: 0
URI:
message: 're_preFlt_txt34' is not defined
Linea: 133
Carattere: 4
Codice: 0
URI:
message: 're_preFlt_txt30' is not defined
Linea: 183
Carattere: 1
Codice: 0
URI:
message: 're_preFlt_txt42' is not defined
Linea: 234
Carattere: 8
Codice: 0
URI:
message: 're_preFlt_txt43' is not defined
Linea: 271
Carattere: 1
Codice: 0
URI:
message: 're_preFlt_txt45' is not defined
Linea: 286
Carattere: 8
Codice: 0
URI:
message: 're_preFlt_txt55' is not defined
Linea: 304
Carattere: 1
Codice: 0
URI:
If I connect in HTTPS with IE8 in compatibility mode I view the image as in attachment with_https.jpg.
Debbie Chang
Hi Dan Dan
I have the same problem with version12.2(55) se5 of 3560X.
And I can't found solution for this issue.
