Catalyst 3650 48ps-s Not c Express Setup
harrywells128
I have just bought a 2nd hand Catalyst 3650 48ps-s. I have been following these instructions but whenever I go to 10.0.0.1 it shows ciscocom.PNG. In the instructions, it shows something else it is meant to show. I have reset the unit multiple times but still can't get it to work. My computer network settings are set to DHCP for IP assignment. I am using a USB to ethernet adaptor on my computer.
Does anyone know how i can get it to Express Setup.
Thanks, Harry
Reza Sharifi
If you have a console cable, try connecting it to the console port of the switch and use the CLI to configure the switch.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/consolidated_guide/b_consolidated_3850_3se_cg_chapter_01.html
