Catalyst 3750 Stack
Maurice Ball
Level 3
Level 3
Is it possible to stack a Catalyst WS-C3750X-24T-L with a WS-C3750X-12S?
The reason I'm asking is that  I stacked the two switches and the stack ports on the WS-C3750Z-24-T is showing status down.
NO-REN-H31-118-sw01#sh switch stack-ports summary
Switch#/  Stack   Neighbor   Cable    Link   Link   Sync      #         In
Port#     Port              Length    OK   Active   OK    Changes   Loopback
          Status                                          To LinkOK
  1/1     Down      None    50 cm     Yes    No     Yes        0        No
  1/2     Down      None    50 cm     Yes    No     Yes        0        No
2 Accepted Solutions
InayathUlla Sharieff
Hi Maurice,
Yes it is possible to have both these switches in stack. One more important thing to note is that the license should be same on both the switches.
3750x switch supports three software feature sets: Lanbase, ipservers, ipbase
Show license detail output from each switch will tell you with what license exactly the switch is running.
please refer to the documentation for more important info and cave
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_55_se/configuration/guide/swstack.html#wp1142379
Hope this helps
Inayath
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
I believe you can mix IP Services and IP Base in the same stack.
Hi Maurice,
Hope this helps
Inayath
Disclaimer
Posting
