Catalyst 3750 Switch Device Manager in Stack issue
dparsons
   I have a stack of 6 3750's.  One had to be replaced and now the SDM is inoperative.  The show switch doesn't indicate a mismatch.  Is there a command I can issue to discover why the SDM is not working from HTTP.
Thankyou,
Denise
9 Replies 9
Nagaraja Thanthry
Have you enabled http server on the stack?
NT
Hi NT,
Yes,  I have it there, "ip http-server".  All looks ok, but not http SDM.  A" show platform stack-manager all" indicates all is good and no mismatches as well.
The SDM template is "desktop default".
From top master to bottom:
WS-C3750G-48TS
WS-C3750-48TS
WS-C3750G-48TS
WS-C3750-48TS
WS-C3750-48TS
WS-C3750-48P
Denise
When you say "no SDM", are you referring to the GUI or something else? If
you are referring to GUI, can you attach the output of "show flash" from the
stack master? Also, the output of "show interface vlan "
would be great.
NT
Yes, it's the GUI access that's not working.
Here are the show command results.
Thanks for such quick replies
Denise
MC_SW3081#sh int vlan 2
Vlan2 is up, line protocol is up
Hardware is EtherSVI, address is 0016.c8b6.5b41 (bia 0016.c8b6.5b41)
Internet address is 10.69.2.243/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 4000 bits/sec, 8 packets/sec
5 minute output rate 3000 bits/sec, 3 packets/sec
78168170 packets input, 1440859699 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicast)
5852049 packets output, 605918419 bytes, 0 underruns
0 output errors, 0 interface resets
MC_SW3081#sh flash
Directory of flash:/
2 drwx 64 Dec 31 1969 20:32:13 -04:00 c3750-ipbase-mz.122-25.SEE1
3 drwx 64 Feb 28 1993 20:02:34 -04:00 update
363 -rwx 4696 Jul 8 2010 13:11:20 -03:00 vlan.dat
5 drwx 128 Feb 28 1993 20:39:31 -04:00 c3750-ipbase-mz.122-25.SEB4
366 -rwx 27 Jul 8 2010 13:11:34 -03:00 private-config.text
6 -rwx 5508786 Feb 28 1993 20:42:48 -04:00 c3750-ipbase-mz.122-25.SEB4.bin
368 -rwx 133233 Jul 8 2010 13:11:34 -03:00 config.text
32514048 bytes total (12944896 bytes free)
MC_SW3081#sh switch
Current
Switch# Role Mac Address Priority State
More information.  I rebooted the stack and cleaned up all the flash files to be the same. c3750-ipbase-mz.122-25.SEE1.bin No change to GUI access to SDM.   SDM template is "desktop default".  One this I did notice was all switches have the IOS in a flash directory except switch 3 is just the .bin file.  Would switch 3 be missing any SDM configurations files ?
Denise
If switch 3 is the stack master, then yes, that would affect the GUI access.Can reboot switch 3 and see if that helps?
NT
Hi NT,
Switch 1 is the master. Here is a copy of the show switch and flash results as well. Looks like switch 3 was upgraded without using the .tar file. Is there anyway to copy to IOS/HTML directory from another switch to this one ?
Denise
MC_SW3081#sh switch
Current
Unfortunately, you cannot copy the folder like that. You could however, install the tar image on switch 3 alone. As far as access to the device is concerned, let us try the following:
On the switch, please issue the following command:
ip http path flash1://html
Hope that fixes the issue.
NT
Hi NT,
That command did not work. So I loaded the latest .tar using the following command and all is working now 100%.
archive download-sw tftp://x.x.x.x/c3750-ipbase-tar.122-53.SE2.tar
Thanks for all your replies.
Denise
