07-21-2020 12:36 PM
Hello, my fiber backbone switch is going EOL, 3750G-12S and I need a comparable replacement. Any suggestions for the next gen of switches that is comparable to the 3750G? Thank you.
Solved! Go to Solution.
07-21-2020 01:01 PM
For replacement, you can use C9300-24S-E. See link to datasheet (table-25):
07-21-2020 01:01 PM
07-21-2020 02:11 PM
Thank you for the info. Very helpful.
07-21-2020 02:44 PM
Glad to help!
Good luck.
07-22-2020 12:25 AM
- You can also start from here :
https://www.cisco.com/c/en/us/products/switches/switch-selector.html
M.
