12-02-2015 12:36 PM - edited 03-08-2019 02:56 AM
After upgrading the IOS on a Cisco Catalyst 3850 and rebooting, the switch gives the following error and can't get out of bootloader mode:
Error loading "flash:packages.conf"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically. The
BOOT environment variable needs to be set to a
bootable image.
I tried to copy a new IOS image onto flash, but I get a message saying that flash is a read only file system. I tried booting from usb and tftp without success. I also tried using the "emergency install feature", but since the sda9: is missing the cat3k_caa-recovery.bin file, that did not work either.
I'd appreciate any suggestions.
Luke
12-02-2015 01:40 PM
Try booting the switch to its previous version of IOS/XE.
switch: boot flash:packages.conf.00-
Alex
12-03-2015 07:44 AM
Alex,
I have tried booting from "flash:packages.conf.00-" before, and tried again after I read your reply, but I get the following error:
Getting rest of image
Reading full image into memory....done
flash:cat3k_caa-base.SPA.03.02.03.SE.pkg: no such file or directory
Error loading "flash:packages.conf.00-"
And as I said before, I am not able to copy anything to flash: because I get an error saying that flash is a "read only file system". I wonder if there is a way to chage it to a read and write file system?
Thanks for your help!
12-02-2015 07:39 PM
hi luke,
i've also encountered the same error and i'd still go for the IOS boot/recover via USB.
make sure the USB key is FAT16 format and older USB with 1, 2 or 4 GB mostly works.
see useful link.
http://wannabelab.blogspot.com/2015/09/cisco-catalyst-3650-ios-recovery-via-usb.html
may the force be with you ;)
12-03-2015 07:38 AM
John,
Thanks for your suggestion. I've tried that before but did not make sure that the USB was FAT16 format. I formated a 1GB thumb drive as FAT16, but get the same error as follows:
### Launching Linux Kernel (flags = 0x5)
All packages are Digitally Signed
Starting System Services
FIPS(NGWC): Flash Key Check : Begin
FIPS(NGWC): Flash Key Check : End, Not Found, FIPS Mode Not Enabled
BIST failed. Abort init ...
I appreciate your help though.
