10-01-2019 06:24 PM - edited 10-01-2019 06:28 PM
Hi All,
I wanted to check-in with everybody and make sure I am not doing this setup any harder than it needs to be.
What I Got:
Where we need to be:
Some problems I have:
My solution would be to do a simple HSRP on the vlans, and OSPF between the two switches and keep them separate. T Can put one dark fiber link on each unit. I would have to deploy another set of uplinks to the 3650’s, which would not be a problem. This would keep everything available, and allow me to take various sides of the core down without impacting everything.
Am I missing something?
10-02-2019 01:38 PM - edited 10-02-2019 01:39 PM
Hello
@Jeffrey6413 wrote:
- I considered using the traditional stackwise setup, but I have found on the 3650 setup that this tends to be very difficult. I have been unsuccessful in running switches within a stack on even slightly different IOS IE: 16.6.0 vs 16.6.1. This makes it hard when doing patching
The first option above would be the most applicable to do and simplest solution, The second option is also seems viable but a lot more administrative - , Can you elaborate on what issues you've had or envisage running the 3860's in stack?
10-02-2019 01:48 PM
Anytime a switch has come up in a 3650 StackWise stack with a slight different IOS in: 16.6.0 vs 16.6.2, it would give an error about version mismatch and not come back up in the stack. So when I did IOS updates, which I try to do about every 3-6 months, I have to reboot the entire stack.
