Catalyst 4000 Interface Last input output
philip-devos
Community Member
Usually check the interface status last been used by looking at the uptime of the switch first and then see when the last time the interface been access by doing the following
Show int f2/7
I then look the Last input and output values to verify when the interface last been used.
But I came across the following problem on a Catalyst 4000
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(25)EWA4, RELEASE SOFTWARE (fc1)
The interface show up but the input and show never
Example below
FastEthernet2/7 is up, line protocol is up (connected)
Last input never, output never, output hang never
Any ideas?
iyde
Level 8
Level 8
Probably IOS error. I have seen various IOS codes on various switches where it claims that no traffic has passed through,e ven though it is a very busy interface.
HTH.
