Catalyst 4500 IOS12.2(25)EWA8 that is continue every 5 minute displaying unknown log.
BeomYong Park
Beginner
Beginner
I have Catalyst 4500 IOS12.2(25)EWA8 that is continue every 5 minute displaying in the log:
I could not found message decoder docs, cisco, any search engines.
What is happening?
Nov 22 14:58:36.713: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 15:03:36.854: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 15:08:36.918: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 15:13:36.958: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 15:18:36.986: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 15:23:37.029: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 15:28:37.113: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 15:33:37.217: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 15:38:37.265: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 15:43:37.321: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 15:48:37.329: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 15:53:37.374: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 15:58:37.445: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 16:03:37.661: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 16:08:37.737: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 16:13:37.837: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 16:18:37.841: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 16:23:37.977: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 16:28:38.237: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 16:33:38.277: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 16:38:38.289: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
Nov 22 16:43:38.553: %C4K_CHASSIS-4-PHONEPOWERENABLESTATEMISMATCH: Kingfish on module 3 : software power enable state enabled hardware power enable state disabled (mismatch)
This is "show ver" displaying
Cisco IOS Software, Catalyst 4000 L3 Switch Software (cat4000-I5K91S-M), Version 12.2(25)EWA8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 24-Jan-07 15:06 by pwade
Image text-base: 0x10000000, data-base: 0x115FE81C
ROM: 12.2(20r)EW1
Dagobah Revision 226, Swamp Revision 34
Switch uptime is 1 year, 49 weeks, 6 hours, 55 minutes
Uptime for this control processor is 1 year, 49 weeks, 7 hours, 22 minutes
System restarted at 10:28:11 KST Tue May 22 2012
System image file is "bootflash:"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4507R (MPC8245) processor (revision 4) with 524288K bytes of memory.
Processor board ID FOX104100K9
MPC8245 CPU at 400Mhz, Supervisor V
Last reset from PowerUp
9 Virtual Ethernet interfaces
62 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Leo Laohoo
VIP Community Legend VIP Community Legend
Sounds like a hardware fault.  Kindly re-seat module 3 and observe if the error message goes away.
Recognize Your Peers
