08-11-2017 08:24 AM - edited 03-08-2019 11:42 AM
I received my Catalyst 4500-X 16 port unit as a part without the ios install. Where can I find the necessary ios files and instruction to get the unit up to where I can start configuration? Thanks.
08-11-2017 08:28 AM
Here are 2 links, one is the installation guide and the other one is the config guide
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500x/installation/notes/OL_24795.html
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-8-0E/15-24E/configuration/guide/xe-380-configuration/pref.html
08-11-2017 08:40 AM
Thanks. My unit came without the ios pre-install. I need to install the ios before I can get to the normal installation and configuration instructions these guides provided.
08-11-2017 08:51 AM
Usually every unit is shipped with an IOS, so you can boot the device and make all the necessary changes. If it did not come with an IOS at all, than you would have to download a version and install it. Here is a link to download it. You would need a valid support contract and a CCO account to download.
https://software.cisco.com/download/navigator.html?mdfid=284222178
