Catalyst 4500-X, VSS, and SVI
meduyek238
Hello, everybody!
I have a proyect to implement the feature VSS, with two catalyst 4500-X, it will be the layer Core/Distribution.
So, I want integrate in the catalyst 4500X, Inter vlan routing (SVI)  and vtp domain,  in the layer access, we´ll have  SW 3750-X  with PoE.
Is possible configure SVI  in my catalyst 4500-X.  to separate traffic across VLANs. and the routing will be in the 4500X too.  ???
My customer does not have sufficient space to mount the serie 4500E in the Rack, so he prefer the 4500-X.
Help me!
Thanks!
Reza Sharifi
Yes, there is no different between a VSS pair and non-VSS when it comes to SVI and inter-vlan routing.  It works the same way as if the 4500-X ware separate.
