Catalyst 4948 Inter SVI max routing rate
AndreiM88
In network is installed Catalyst 4948 with two Link Aggregation interfaces. Each ether-channel aggregates 8 (eight) 1G physical interfaces. Switch is used as Layer 3 device, so two ether-channels are in different networks. The question is the following:
What is supposed to be max routing rate between two ether-channels?
Best Regards
michael o'nan
Level 4
Level 4
The 4948 has 96Gbps backplane switching capacity.
