Catalyst 5500 Switch Upgrade Issue
jsilas007
I have a Cisco 5500 Switch with sup module, 1000BaseX Supervisor IIIG (WS-X5550). I'm having issue upgrading this switch, when I try to upgrade it tells me unable to do so. I was thinking it's related to the supervisor module.
glen.grant
Should not be a problem , make sure you are using the correct image , the 3G takes it own special image . Also make sure the rommon is up to date for the image you are trying to use . And last you need enough space in bootflash to download the image . Squeeze bootflash to create enough room , if not enough room then you would need to delete the running image and squeeze the space and download the correct image then change your boot statement . What is the message that you get specifically ?
