Join Customer Connection to register!
276
boonchin.ng
Beginner
Catalyst 6000 Supervisor Engine 2 ROMMON Upgrade
I am unable to upgrade the ROMMON to release 7.1(1).
When I entered the upgrade rom-monitor command, instead of running the upgrade process it just copying the .srec file from tftp server.
Please kindly advice.
4 REPLIES 4
Amit Singh
Hello Friend,
As per the output attached you are on RP. Try the following and paste the output:
Router# remote command switch show version
The above should work and give you the output from SP.If you face any issues, try
Router# remote login switch
and then do the show version.
Check the boot rom strap version there.
HTH,
-amit singh
Attached is the details for [remote command switch show version]
Amit Singh
Also, did you try reloading or resetting the sup engine after rommon upgrade?
-amit singh
Yes. I did
