06-24-2011 02:01 PM - edited 03-07-2019 12:58 AM
the new line card WS-X6716-10T-3C support a server at 1Gbps or only works at 10Gbps?
Alejandro
Solved! Go to Solution.
06-24-2011 02:46 PM
https://supportforums.cisco.com/thread/2059909
Seems from datasheet, not mention about 1G or other speed, as discussed in above chain, it is 10 G only.
06-24-2011 05:46 PM
The WS-X6716-10T card will support any speed as long as it's 10Gb. The logic behind this is why would you want to purchase a very expensive 10Gb card and let it run 1Gb when there is the less-expensive X6748 card?
06-24-2011 02:46 PM
06-24-2011 05:46 PM
