Catalyst 6500 LSNAT
mbrito_rj
Hi Guys!
I need some help with a project in my company. Our Core switches are Enterasys N7 and we want to migrate to Catalyst 6509. We use LSNAT on the N7 to loadshare the traffic between our application servers. I know I can do that with the ACE module, but with all this rumors about it been discontinued I am worried to buy the ACE module and it became discontinued in the near future.
Is there any feature that is equivalent to LSNAT on the 6500?
thx
Marcio Brito
InayathUlla Sharieff
Hi Marcio,
Yes we do offer this capability in the 6500 with multiple
levels of performance and price. At the low end there is Cisco IOS
server load balancing, which supports multiple methods of performing
server load balancing including using NAT for what is called "directed
mode" server load balancing. At the higher end we have the more
scaleable solutions using service modules such as the ACE and CSM.
So choosing the best method depends on what the solution requirements
are.
Here is some info on IOS SLB
http://www.cisco.com/en/US/docs/ios/ipapp/configuration/guide/ipapp_slb.
html#wp1054878
Info on the ACE
http://www.cisco.com/en/US/products/ps5719/Products_Sub_Category_Home.ht
ml
IOS-SLB combines load sharing and NAT capabilities, as do the ACE and CSM
service modules.
Here is information about IOS-SLB with NAT  :
http://www.cisco.com/en/US/docs/ios/12_2sx/feature/guide/slbsxf7.html#wp2143
672 .
Inayath
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Hi Marcio,
are.
html#wp1054878
Info on the ACE
ml
service modules.
672 .
Inayath
Thanks for the help!
Can I implement this feature on IOS 15.0 IP Service, or do I need the advanced version to run SLB?
thx
Marcio Brito
Hi Marcio,
3. Supported Hardware and Software Platforms
Hardware
Software Release
Cisco Catalyst 6500 Series/7600 Series Supervisor Engines 720-3B and 720-3BXL
(WS-SUP720-3B and WS-SUP720-3BXL)
Cisco IOS Software Release 12.2(18)SXD and later
Cisco Catalyst 6500 Series/7600 Series Supervisor Engines 32-GE-3B and 32-10GE-3B
(WS-SUP32-GE-3B and WS-SUP32-10GE-3B)
Cisco IOS Software Release 12.2(18)SXF5 and later
Ordering Information
Table 4. Cisco IOS SLB and Exchange Director Ordering Information
Product Number
Product Description
FR-IOSSLB
FR-IOSSLB=
Cisco IOS Server Load Balancing Feature License
• IP Services Cisco IOS package required
REgards
Inayath
