Highlighted
Beginner
Catalyst 6500 SPAN problems - part of the traffic not visible
Consider the following configuration:
hardware: Catalyst 6500E with Supervisor Engine 720
switch#sh monitor
Session 10
Type                   : Local Session
Source VLANs           :
    Both               : 10-14,18,189,211,213-214,223-224,240,242,244-245,264-265,267,270,272,274,520,522-523,525,527-533,536-537,539,547
Destination Ports      : Te6/1
Egress SPAN Replication State:
Operational mode       : Centralized
Configured mode        : Centralized (default)
As You can see, there are a lot of VLAN's (and a lot of traffic) going through this SPAN session.
One of the SPAN'ed VLAN's is VLAN10, with following SVI config:
interface Vlan10
ip address 10.1.10.2 255.255.255.0
ip flow ingress
standby 10 ip 10.1.10.1
standby 10 priority 130
standby 10 preempt
standby 25 ip 10.1.10.4
standby 25 priority 130
standby 25 preempt
standby 35 ip 10.1.10.7
standby 35 priority 130
standby 35 preempt
end
Problem is, that traffic directed to HSRP gateway in group 10 is not visible in SPAN session. When default gateway on host is changed to virtual address in group 25, traffic from this host appears on SPAN destination port as expected.
Any thoughts on what could cause such behavior?
WM
1 REPLY 1
Highlighted
Participant
Hello.
1. Is vlan 10 in group 10 active in this switch?
2. If you check the arp table of one host in vlan 10, with the command arp -a (windows) is it pointing to the mac address of vlan 10 group 10 in the 6500?
3. What if you span the ingress physical ports of the 6500? do you see traffic in vlan 10?
Regards.
Wilson B.
Content for Community-Ad
