08-24-2017 02:56 AM - edited 03-08-2019 11:49 AM
Hi!
Recently we got issues with our Cat 6500 (2x SUP720)
SP util is high but it's not interrupt based.
There are many tshoot articles regarding traffic / interrupt based problems but here it looks that process kills my guy.
For now I kinda cannot reboot / swap supervisors, etc (I need to wait for TW if doing so).
See me SP util stats with "heartbeat process" at the very top
sw#remote command switch show processe cpu sort
CPU utilization for five seconds: 99%/5%; one minute: 99%; five minutes: 99%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
102 1516076 164598279 9 100.00% 53.05% 56.05% 0 Heartbeat Proces
297 187048188 572222625 326 7.85% 6.59% 6.61% 0 Spanning Tree
486 25630268 67979841 377 3.69% 1.30% 1.26% 0 LTL MGR
114 22439876241738490297 1290 3.14% 3.46% 3.53% 0 slcp process
269 2707503320 111421942 24299 1.72% 0.79% 0.79% 0 Vlan Statistics
Any hints to solve this?
Thanks in advance
Solved! Go to Solution.
08-28-2017 04:17 AM
It seems we've solved the problem
I'm posting this for further reference
We've reviewed HSRP config for 2 switches working in pair (where one of them had SP at 100% util.) We ordered the priorities + added preempt on both sides for every HSRP gateway
Also we've added to every SVI:
interface Vlanxxx
no ip redirects
no ip proxy-arp
standby 0 preempt
standby 0 priority 200 (when necessar)
arp timeout 1500
And SP util. went down to 40%. It works like this 3rd day in a row.
08-24-2017 03:11 AM
08-24-2017 04:02 AM - edited 08-24-2017 07:31 AM
Thanks for reply
RP is ok, i's SP which gets high.
Below you'll find show output requested (full output attached in file)
sw#show version
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXI9, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 24-Feb-12 21:38 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
sw uptime is 5 years, 3 weeks, 6 days, 3 hours, 58 minutes
Uptime for this control processor is 5 years, 3 weeks, 6 days, 3 hours, 47 minutes
Time since sw switched to active is 4 weeks, 1 day, 10 hours, 27 minutes
System returned to ROM by Stateful Switchover at 22:19:22 CET Fri Oct 9 2009 (SP by power-on)
System restarted at 08:49:46 CET Sun Jul 29 2012
System image file is "sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXI9.bin"
Last reload reason: reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6513 (R7000) processor (revision 2.0) with 983008K/65536K bytes of memory.
Processor board ID XXXXXXXXXXX
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
4294967294 Ethernet interfaces
66 Virtual Ethernet interfaces
452 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
sw#sho proc cpu sort | ex 0.00%
CPU utilization for five seconds: 8%/2%; one minute: 11%; five minutes: 11%
11 24242396 47617397 509 1.19% 1.11% 1.14% 0 ARP Input
121 287896 1951815 147 1.03% 0.82% 0.82% 0 CDP Protocol
256 20047944 256422482 78 0.87% 0.89% 0.91% 0 IP Input
446 51836168 351091288 147 0.71% 1.89% 1.94% 0 Port manager per
48 5109800 25330285 201 0.31% 0.32% 0.45% 0 Logger
323 7080068 191081744 37 0.23% 0.19% 0.18% 0 CEF: IPv4 proces
23 13864728 199813645 69 0.23% 0.33% 0.43% 0 IPC Seat Manager
137 9960 11675 853 0.23% 0.05% 0.01% 5 SSH Process
515 2558441366302949 0 0.15% 0.21% 0.23% 0 HSRP Common
279 2018443081601723 0 0.15% 0.14% 0.15% 0 Ethernet Msec Ti
516 2599904 60770574 42 0.15% 0.10% 0.08% 0 HSRP IPv4
347 2108884 80013108 26 0.07% 0.03% 0.03% 0 HIDDEN VLAN Proc
129 92228 518304 177 0.07% 0.04% 0.05% 0 Compute load avg
445 328772 691224163 0 0.07% 0.05% 0.07% 0 PM Callback
239 2799032 9683125 289 0.07% 0.11% 0.12% 0 Earl NDE Task
520 889900 539279306 1 0.07% 0.07% 0.07% 0 EIGRP-IPv4 Hello
501 32910688 92128769 357 0.07% 0.18% 0.23% 0 SNMP ENGINE
85 2484936 55982095 44 0.07% 0.03% 0.02% 0 ARP HA
50 2517304 159974297 15 0.07% 0.08% 0.07% 0 Per-Second Jobs
sw#remote login switch
Trying Switch ...
Entering CONSOLE for Switch
Type "^C^C^C" to end this session
sw-sp#show processes cpu sort
CPU utilization for five seconds: 99%/3%; one minute: 99%; five minutes: 99%
102 1517012 164608343 9 100.00% 50.71% 54.92% 0 Heartbeat Proces
297 187357416 572261698 327 6.27% 6.54% 6.45% 0 Spanning Tree
114 22441355681738622319 1290 3.49% 4.25% 3.67% 0 slcp process
502 33010632 47541673 694 2.85% 1.29% 1.17% 0 SEA write CF pro
225 22292764 291875318 76 0.71% 0.71% 0.71% 0 cpf_process_tpQ
539 4629012 18110937 255 0.71% 0.10% 0.07% 0 DiagCard11/-1
535 3727832 21243014 175 0.55% 0.07% 0.04% 0 DiagCard6/-1
127 3692828 21154205 174 0.47% 0.06% 0.04% 0 DiagCard3/-1
540 4786868 19122967 250 0.39% 0.16% 0.08% 0 DiagCard12/-1
537 4783620 19109410 250 0.39% 0.14% 0.08% 0 DiagCard9/-1
93 118981224 83226500 1429 0.39% 0.30% 0.25% 0 Compute load avg
494 31195764 215149470 144 0.31% 0.33% 0.36% 0 NDE - IPV4
538 4780320 19087764 250 0.23% 0.20% 0.10% 0 DiagCard10/-1
129 3881532 22984558 168 0.23% 0.53% 0.36% 0 RFS server proce
340 233968 2667255 87 0.23% 0.27% 2.49% 0 XDR LC PRIO Crit
533 4119600 25398817 162 0.23% 0.12% 0.07% 0 DiagCard4/-1
376 8589132 3059603 2807 0.23% 0.36% 0.35% 0 Env Poll
299 28166561743916415 1 0.15% 0.14% 0.15% 0 UDLD
314 41379961569570387 2 0.15% 0.17% 0.13% 0 Mcast Hw Agent6
353 1265780841986742713 63 0.15% 0.46% 0.29% 0 mls-gc Process
143 584 1799 324 0.15% 0.44% 0.12% 0 RFSS worker proc
416 44745044127867871 0 0.07% 0.08% 0.07% 0 PM Callback
283 7448832 97018485 76 0.07% 0.04% 0.05% 0 Netflow Aging Ta
75 69994976 396199822 176 0.07% 0.18% 0.16% 0 SCP Download Lis
531 2145700 12527586 171 0.07% 0.07% 0.06% 0 DiagCard1/-1
94 796328 5003641 159 0.07% 0.04% 0.05% 0 OIR Process
331 3876136 193524154 20 0.07% 0.04% 0.05% 0 CEF LC Stats
265 10562548 72072076 146 0.07% 0.23% 0.19% 0 SCP async: LCP#1
08-24-2017 05:20 AM
Read THIS.
08-24-2017 06:01 AM - edited 08-24-2017 06:18 AM
Thanks for reply, but... you're sure?
I've read this one before & the article focuses on debug what comes into SP
I have no high CPU utilization due to excessive traffic, but due to internal process
Should I do "debug netdr capture rx" despite the difference?
I did some of that tshoot session show outputs, but for debug I'll need to wait after business hours (please reply if netdr results would be helpful here). The rest - attached
08-28-2017 04:17 AM
interface Vlanxxx
no ip redirects
no ip proxy-arp
standby 0 preempt
arp timeout 1500
