08-23-2010 09:40 AM - edited 03-06-2019 12:36 PM
I have a 6509 (Sup 720-3B) that upon reboot- just goes straight to the Rommon prompt. I've done everything according to the following article:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa1.shtml
All of the information shows correct - even on the set printout on the rommon upon reboot, and once the router is booted. When you get to the rommon port- all you have to type is boot and it does. It just looks like autoboot is not on. Any ideas?
Greg
Solved! Go to Solution.
08-23-2010 10:05 AM
It should be 2102. Can you try setting it again on the RP and then save the config and rerun the 'remote command switch show bootvar' command. If it shows 0x2102 at next reload then I believe it should fix it. I dont exactly recall how I fixed it but I am sure if this is not the correct way someone else will provide you with the exact answer :- ).
Atif
08-23-2010 09:56 AM
I have seen a similar issue in past but that was a mismatch in config register between RP and SP. I am assuming once it boots correctly you have verified that the config registers are same on both the RP and SP using the 'remote command switch show bootvar' or 'remote command switch show ver' commands?
08-23-2010 09:56 AM
Hello Greg,
Can you send the output of "remote command switch show version"?
-Matt
08-23-2010 09:59 AM
DAL-COLO-6509-1#remote command switch sh ver
Cisco IOS Software, s72033_sp Software (s72033_sp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXH7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 11-Mar-10 21:08 by prod_rel_team
ROM: System Bootstrap, Version 8.5(3)
DAL-COLO-6509-1 uptime is 52 minutes
Time since DAL-COLO-6509-1 switched to active is 51 minutes
System returned to ROM by reload at 15:32:43 CDT Fri Aug 6 2010
System restarted at 11:06:23 CDT Mon Aug 23 2010
System image file is "bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXH7.bin"
cisco Catalyst 6000 (R7000) processor with 983008K/65536K bytes of memory.
Processor board ID SMG0623A04J
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
144 FastEthernet interfaces
34 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
500472K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
Configuration register is 0x2100
08-23-2010 10:00 AM
DAL-COLO-6509-1#remote command switch sh bootvar
BOOT variable = bootflash:s72033-advipservicesk9_wan-mz.122-33.SXH7.bin,12;
CONFIG_FILE variable does not exist
BOOTLDR variable =
08-23-2010 10:05 AM
Atif
08-23-2010 10:46 AM
This fixed the issue. The different config registry wasnt showing up on the Route Processor- so this fixed the issue.
Greg
08-23-2010 10:28 AM
In global configuration mode, issue the config-register 0x2102 command, and set the configuration register to 0x2102 for both the RP and the SP.
6500_SW1(config)# config-register 0x21026500_SW1(config)# end
To verify the configuration register value at the next reload, issue the show bootvar command.
6500_SW1# show bootvar
BOOT variable = "bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXH7.bin"
CONFIG_FILE variable =
BOOTLDR variable =
verify that the configuration register on the SP also changed.6500_SW1# remote command switch show bootvar
BOOTLDR variable =
Configuration register is 0x2 (will be 0x2102 at next reload)
Reload the switch for the new SP configuration register setting to take effect.
