10-10-2021 11:26 PM
Hi board,
Is there a way to transport SGT information in a EVPN network?
In SDA, the VXLAN header is slightly modified in the reserved bits to transport the SGT.
Is there a way to do this in EVPN as well? Haven't found any documentation on this.
Solved! Go to Solution.
10-11-2021 06:04 AM
@Johannes Luther and @Georg Pauwen ,
We do not support EVPN + SGT with Cat9K and as far as I know there are no plans for this.
Cheers,
Scott Hodgdon
Senior Technical Marketing Engineer
Enterprise Networking and Cloud Group
10-11-2021 12:36 AM
interesting question and subject. I (think I) really looked all over the place, but could not find a single reference to SGT over EVPN, so it looks like a bridge too far for now. In the Cisco world, even SGT over VXLAN seems to be limited to the newer Nexus 7/9K and Catalyst 9K switches.
The closest reference I could find is in the Juniper document linked below, where they talk about EVPN-VXLANs, so maybe that is where the future development will be...
https://manuals.plus/m/aec8eed5cb4683320544d4ad586d7e57f1cc1525a3a936ba68f4ac6a863bfbe3.pdf
10-11-2021 12:43 AM
Hi Georg,
thanks for the reply. My main focus is Cat9k. I don't consider older platforms like Cat3k, 6k etc. So from my point of view, even if it's supported, it's only supported on C9k Campus platforms.
I found out another potential source for information:
For the C9k platform the SGT inline tagging support is: "SGT over VXLAN"
However, it's not clear whether this refers to SDA only or if it's supported with EVPN as well.
10-11-2021 06:04 AM
Cheers,
Scott Hodgdon
10-11-2021 06:27 AM
Hi Scott,
thank you for the answer.
So if someone seeks for SGT-based microsegmentation within a VRF (VN), SDA would be the correct solution.
If someone wants a fabric in the Campus, but does not need SGT-based microsegmentation, SDA or EVPN would be a viable solution.
10-11-2021 06:39 AM
Correct.
Cheers,
Scott Hodgdon
