Catalyst 9000 Plenum rated?
vecarpen
Team, are any of the new Catalyst 9000 Access switches Plenum rated.  I don't see any that are fanless capable but I need to ask for a public opportunity.
balaji.bandi
i do not believe cat 9K has the fan less feature.  since it required Fan to evacuate the heat from the device.
BB
Reza Sharifi
Some models with specific power supplies are plenum-rated.
 C9300-48UN, C9300-24UX, C9300-48UXM are available with PWR-C1-1100WAC-P Platinum-rated power supply. Platinum-rated power supplies are more efficient, lowering operating power costs
* PWR-C1-1100WAC-UP and PWR-C1-715WAC-UP Platinum-rated power supply upgrade options are available to upgrade the default AC power supply to 1100W or 715W
See table-2 in this link:
Do you mean plenum as is safe to use in environmental air space like a drop ceiling? I am not environmental expert, but probably anything with any plastic will give off toxic fumes when it burns, so I find it pretty unlikely any ethernet switch would safe to use in a drop ceiling/environmental air space.
