Catalyst 9000 Switches
shafiq_84
We have 2 unit Cisco 9200L with POE (Cisco IOS XE Gibraltar), When we configure trunking port on Gi1/0/24 for both switch, then connect with UTP cable, the port is not functioned.
The command for each port:
Switchport mode trunk
Switchport trunk allowed vlan all
power inline never
Can someone help me on this issue, or anybody have the solution for this issue
balaji.bandi
it should work as expected.
steps i follow :
1. change with new cable ? and test it.
2. is this switch next to each other or different location ?
3. what happends if you connect laptop or any other device this port ? is this port come up ?
4. some time by default ports are i shutdown mode try below both the siwtch ?
config t
interface gi 1/0/24
no shut
end
Still not working -  Can you post-show interface gi 1/0/24 from both the switches?
BB
Hello
Are these two switches stacked together or you connecting them together via a trunk on port gig1/0/24?
Kind Regards
Paul
Leo Laohoo
Do the following:
test cable tdr interface <PORT>
Wait for approximately 7 to 10 seconds
show cable tdr interface <PORT>
Post the complete output.
