05-20-2025 06:31 PM
Would be possible to connect C9200L-48L-4X (C9200L - access switch) to C9500-16X using SFP-H10GB-CU3M cable DAC? I have this doubt because SFP-H10GB-CU3M is a passive twinax cable...
Solved! Go to Solution.
05-20-2025 09:53 PM
Hello @Kristiane Araujo
You can use the SFP-H10GB-CU3M DAC cable to link your C9200L to a C9500-16X, since both ends use supported Cisco DAC...
Check the compatibility here: https://tmgmatrix.cisco.com/
I check and I see it is compatible...checl also the minimum ios version if necessary.
05-20-2025 09:53 PM
