Catalyst 9200L Cipher Mismatch
I've just taken delivery of 4x Cisco Catalyst 9200L switches.
These are my first Cisco switches in about 8 years.
I am trying to connect to the web ui of one of these to start configuring it, however when doing so from IE, Edge or Firefox, I get an ERR_SSL_VERSION_OR_CIPHER_MISMATCH error.
Can anyone help me determine why this issue exists on brand new switches?
James
Thanks to everyone else for the help and advice.
Summary answer is;
Until you connect to the console and run through the basic switch setup, SSL configuration is not completed on the switch, causing the web interface to not load.
Once you connect to the console port and run through the basic setup, it will sort the SSL config and the webui will then load (albeit with a self signed cert error (to be expected)).
James
20 Replies 20
balaji.bandi
what terminal client you using
get new Putty client and install  and test it
Secure CRT
BB
I'm trying to get to the webui!
Try different Browser, since its not valid SSL, you get that error,
BB
Sorry, but if you re-read my post, you'll see I've already tried 3 browsers. All have the same issue.
I may have over looked the information  :  ( let me test myself again) mean time try below may work :
Do you have enabled on the browser  - enable  the TLSv1.1 & TLSv1.2
https://help.wheniwork.com/articles/enable-tls-v12-on-your-web-browser/
BB
Yes both 1.1 and 1.2 are enabled.
Are you using a Win7 machine?
Windows 10
Do you have any other device ? (Pc) to test
BB
marce1000
      - Try :
  conf t
no crypto pki trustpoint TP-Self-Signed-xxxxxxxxxx
no ip http server
no ip http secure-server
ip http server
ip http authentication
        This should regenerate a new self signed trustpoint
 M.
 - Actually pre-pend the latter with : show run | inc crypto first
 M.
Is there a doc you can point me to advising how to set up one of these switches via Putty? I've skimmed the docs I've found for the 9200L, but they are dense and I couldn't find anything about CLI configuration.
James
 - https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/software/release/16-9/configuration_guide/sec/b_169_sec_9200_cg/configuring_secure_shell__ssh_.html
 M.
Is there a doc that precedes this?
I.e. one that tells me how to connect to the console/management interface for the very first time?
EDIT: Nevermind, think I found it.
