Catalyst 9200L stacking question
michaeldillard
I have been tasked with creating a 9200L stack at a remote site. The existing switch is a 9200L-24P-4G. The only switch i have on hand to ship to Houston is a 9200L-24P-4X. I am assuming this will be fine as i have not seen any documentation to tell me otherwise. Same base model (9200L-24P) running the same version software (17.03.04 CAT9K_LITE_IOSXE) and the same Technology package (network-advantage)   Only difference being the speed capabilties of the fixed uplink ports.
Should i be concerned? Not wanting to fly out there and the project fail.
M02@rt37
Hello @michaeldillard,
The Cisco Catalyst 9200 Series Switches provide the flexibility for mixed-mode support between different models in a single stack ring. You can mix switches with different model variants (PoE, data, Multigigabit) and different network modules in the stack; however, it is not possible to mix the 9200 and 9200L models due to different stacking bandwidth.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-stackwise-architecture-cte-en.html
Then you're OK with your two C9200L models running the same version software (17.03.04 CAT9K_LITE_IOSXE) and the same Technology package (network-advantage).
Best regards
M02@rt37
Best regards
michaeldillard
Thank you so much! Greatly eases my mind
