01-28-2020 03:45 AM - edited 01-28-2020 03:58 AM
Hi Team,
While I was to try configuring Micro BFD using the attached template, I have faced the problem with the BFD commands in the port-channel, could you please help me how to deal with this issue.
Bellow is a command:
Admin-DC-MW(config-if)#port-channel ?
min-links Minimum number of bundled ports needed to bring up this port channel
standalone-disable Ports will go to suspended mode if peer does not respond. Use with [no] prefix for independent mode.
Admin-DC-MW(config-if)#port-channel bfd ?
% Unrecognized command
% Invalid input detected at '^' marker.
Device information:
Version 16.12.1
C9300-48P
01-28-2020 05:23 AM
Do you have bfd-template created ?
can you post below output (if possible full configuration)
show run | in bfd-temp
show run interface port-channel X (X is where you applying this macro)
01-28-2020 09:41 AM
Admin-DC-MW(config-if)#do sh run int port-ch 11
Building configuration...
Current configuration : 225 bytes
interface Port-channel11
description To-BR4-Tower-MW
no switchport
ip address 192.168.56.49 255.255.255.240
ip ospf message-digest-key 1 md5 #BrMic@3
ip ospf priority 255
bfd interval 300 min_rx 300 multiplier 3
Admin-DC-MW#show running-config | i bfd
bfd-template single-hop To-BR4
01-28-2020 08:11 AM
To configure BFD for a Portchannel, you simply go to that Portchannel interface and configure bfd.
example:
config t
inter po10
bfd interval xx (this command will enable bfd).
01-29-2020 03:49 AM - edited 01-29-2020 03:51 AM
I have tried to configure BFD using the this commands but still not showing that any BFD neighbors
