Catalyst 9300
When the 9300 switch is started for the first time, a constant reboot occurs, an emergency installation with an update to the latest firmware did not help, it is impossible to rename or delete the settings files, it is impossible to enter rommon mode
Инициализация оборудования...
Начальная загрузка системы, версия 17.2.1r[FC1], ВЫПУСК ПРОГРАММНОГО ОБЕСПЕЧЕНИЯ (P)
Составлено Чт 20.02.2020 23:47:51.50 по rel
Текущий образ ROMMON: Основной
Причина последнего сброса: SoftwareReload
Платформа C9300-24P с 8388608 Кбайт основной памяти
загрузка: попытка загрузки с [flash:packages.conf]
загрузка: чтение файла packages.conf
Jan 24 04:29:38.499: %PMAN-3-PROCHOLDDOWN: R0/0: The process cmand has been helddown (rc 134)
Jan 24 04:29:38.595: %PMAN-0-PROCFAILCRIT: R0/0: pvp: A critical process cmand has failed (rc 134)
Jan 24 04:29:38.657: %PMAN-3-RELOAD_RP: R0/0: pvp: Reloading: Switch will be reloaded
Chng, reason - Non participant detected
Jan 24 04:29:39.410: %PMAN-5-EXITACTION: F0/0: pvp: Process manager is exiting: reload fp action requested
Jan 24 04:29:40.709: %PMAN-5-EXITACTIOvp: Process manager is exiting: Critical process cmand fault on rp_0_0 (rc=134)
Jan 24 04:29:41.791: %PMAN-3-PROCESS_NOTIFICATION: R0/0: pvp: System report /crashinfo/system-report_local_20220124-042941-Universal.tar.gz (size: 2434 KB) generated
switch: delete packages.conf
Are you sure you want to permanently delete "packages.conf"? y/n [n]: y
ОШИБКА: не удалось удалить файл packages.conf (не поддерживается)
Mark Elsen
      - Checkout : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvt22293 and https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwa73033
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
It was possible to launch on version 16.06.03. Upgrade to the new version 16.6.12. 17.2.1 failed, the error returned. At the same time during the download: System Bootstrap, Version 17.2.1r[FC1], RELEASE SOFTWARE (P), after the download version 16.06.03
Deepak Kumar
Duplicate thread - seems a bug  https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvt22293
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
