Catalyst 9410R Switch
giovane
Hello everyone,
I have a question regarding the software on chassis IOS XE software version for the Catalyst 9410R switch. I need to upgrade to the latest version 17.9.x but Cupertino-17.9.7 is not the recommended version, it's Cupertino-17.9.6a.
Is there any potential impact of updating to Cupertino-17.9.7?
Thank you.
Jens Albrecht
After release of a new software version it always takes a couple of weeks until it becomes the recommended version.
The reason is pretty simple. There is always a chance that one of the fixes contained in the new version has some negative side-effects which have not been noticed during internal testing at Cisco. Hence Cisco monitors the customers' feedback and if no problems are reported for some time then the golden star moves to the new version.
Therefore it is best practice to use the recommended version in production networks.
Of course, there is one exception. If the release notes list a fix for a caveat that might affect your network, then you go for the new version directly.
HTH!
6 Replies 6
Jens Albrecht
HTH!
thank you for the response, in our case we want to upgrade to 17.9.7 version because of this security alert on snmp :
Cisco IOS, IOS XE, and IOS XR Software SNMP Denial of Service Vulnerabilities
so do you advise us to do the upgrade because there is a high denial of service security ?
regards
Jens Albrecht
The best answer is... it depends.
You have to calculate the risk of someone exploiting the SNMP vulnerability versus the risk of running into some unknown issue with the new software version.
Just an example: If you run a strict OOB management strategy with ACLs and firewalls preventing SNMP traffic from any other network, then there is probably not much to worry about regarding such SNMP vulnerabilities.
It is also best practice to have your own POC lab where you can test any new software or configuration changes.
So you need to take a look at your network, check the actual attack surface of any vulnerabilities and then make your own decision.
Joseph W. Doherty
Well yes, hopefully it will be "better" than an earlier version.  Unfortunately, that's not 100% guaranteed.
I assume your question really is, given a choice between a recommended (gold star tagged) version, and new subsequent, and sequential, release, which should be preferred?
However, if "the policy" is to use the "latest" Cupertino release (". . . I need to upgrade to the latest version 17.9.x but Cupertino . . ."), that would be .7, correct?  Unless you're questioning that policy, or setting such a policy, your question is moot, isn't it?
Policy requirements aside, this really is a difficult question to answer.  I assume you're trying to obtain the most stable version of Cupertino, and, again, there's no guaranteed way (as of yet) to determine that, answer.
Heck, the whole point of a recommended version is, it's the vendor's "best of the litter" opinion, but, interestingly, in this case, you note the recommended version is .6a, and I recall (?), lettered suffix releases are made when there's a bit of an "oops" with the published release.  I.e. some issue(s) found, significant enough, that a correction for .# could not wait until .#+1 (or even another suffix letter release is needed, e.g. #a, #b, etc.).
However, if this is a choice you can make, and perhaps, one that will help refine a policy, some thoughts . . .
I would recommend reading the release notes for the .7 release, and see if there are any fixes made to it, that would worry you if known to still be in .6a.  Also noting, how many changes were noted made in the .7 release.  If the former, you would probably want to go with the newer .7 release.  If few changes were made to .7, that possibly reduces the chances of introducing new bugs, you might want to use it, as it's very likely to become the next recommended release.
If neither is the case, next I would look at how long the .7 release has been publicly available.  If it just came out, it's less likely it has been widely deployed by customers, so its quality is yet to be customer confirmed.  So, you might want to just install the recommended version, and treat it, .7, however you normally would follow-on updates.
Also, in general, and if possible, any new software installation, should likely have extra scrutiny for new issues, for sometime; be a phased rollout, both in numbers of platforms updated, overtime, and potential (i.e. particularly sensitive) "location" impact, if defective; and plan for a quick roll back.
BTW, @Jens Albrecht noted, vendors, such as Cisco, often do monitor customer feedback, in making recommendations.  But, what we aren't often told, is how many customers are using the product.  Further, vendors, themselves, often don't know, the details of the customer usage of their product.  So, customer feedback, although valuable, itself, also doesn't guarantee software is stable.
Another issue, is the "catch-22", i.e. customers may be reluctant to run software that's not "tagged" as stable, but if customers don't run non tagged software, we don't get widespread customer usage feedback that helps us determine quality.
Personally, I can attest to, when I would run into software bugs, it often was in using "exotic" features, i.e. features not widely used.  Or, read the known bugs release notes.  Many of them probably are of the class, "what's that for".
In theory, newer maintenance release should always be better, but in practice, that's not always the case, but, odds usually favor the former over the latter.
Leo Laohoo
All software releases, particularly multi-release trains, will get the much-coveted "star" -- Read between the lines.
The "star" release is not the same as the "Safe Harbor".  Safe Harbor had a certain level of "guarantee" that the specific software version had undergone a series of exhaustive testing by Cisco.
"Star" release, however, is just symbolic.  That's all it does.  According to a Cisco staffer, "a bunch of old people" gather around a meeting room every month to ask if "version X.Y.Z" can be made "star".  That's all it takes.
Whoa, I totally forgot about "Safe Harbor" certifications, although, one reference I just saw appears to note Cisco has stopped "Safe Harbor" testing.  BTW, Leo, your reference starts with a "Safe Harbor" statement, but the presentation doesn't seem to be about "Safe Harbor" testing or certification.(?)
Possibly germane to this discussion: https://networkengineering.stackexchange.com/questions/26181/cisco-6500-series-and-safe-harbor-testing  (I.e. to upgrade or not to upgrade.)
When you mentioned "Safe Harbor" I also then recalled Cisco's FIPS, but it's much more narrow, and a "different animal".
