Catalyst 9500 - MPLSoDMVPN
Antho_Balitrand
Hello CISCO community !
Does any of you have tested MPLSoDMVPN (mGRE) with NHRP on Catalyst 9500 ?
We have this solution running on our distribution (6880 switches) with no issues.
The same configuration on Catalyst 9500 (C9500-16X-A) running either 16.9.2 or 16.10.1 does not works at all.
BGP routes are perfectly exchanged, packets are correctly routed and sent over the tunnel, responses are also received, but seems completely ignored by the switch...
If you have some experience of feedback using this configuration on those new switches...
Best regards
0 Replies 0
