09-29-2017 10:55 AM - edited 03-08-2019 12:12 PM
Hello experts.
Today I have a customer using Cat6500 with 215 PvRSTP+ .
Does the Catalyst 9500 family supports 215 or more PvRSTP+ instances as standalone?
I read that when using Virtual StackWise it supports up to 128 PvRSTP+, could you please confirm that?
Thanks in advance.
Nor.
Solved! Go to Solution.
09-29-2017 11:32 AM
Catalyst 9500 supports a maximum of 128 spanning-tree instances.
"The device supports per-VLAN spanning-tree plus (PVST+) or rapid PVST+ with a maximum of 128 spanning-tree instances. One spanning-tree instance is allowed per VLAN."
source: VLAN Configuration Guide, Cisco IOS XE Everest 16.5.1a (Catalyst 9500 Switches)
I hope this helps. Good luck!
-Austin
09-29-2017 11:32 AM
-Austin
