03-20-2020 11:54 AM - edited 03-20-2020 12:48 PM
I am confused by this restriction on SVLs in the IOX-XE 16.12 HA Configuration guide:
The word "support" confuses me...don't all the 40G-capable ports on the C9500 "support" QSA & QSFPs with breakout cables? Should the statement maybe really read "...ports USING 4X10G breakout cables or a QSA can only be used as data-only ports"?
For instance, I would like to designate say, ports 50 & 52 on a C9500-48Y4C as SVL ports using QSFP-40G-LR4-S or maybe QSFP-40G-SR-BD. Should I expect this to work? I'm familiar with the restriction on not mixing uplink module ports and downlink ports to create a SVL. But in this case, I just want to use the built-in QSFP ports (without using a breakout cable or QSA).
Solved! Go to Solution.
03-20-2020 12:55 PM - edited 03-20-2020 12:57 PM
The way I understand this is, as long as you are not using a QSA or breakout cable, you should be fine. So, yes BIDI and standard optics should work just fine.
03-20-2020 12:56 PM
Hi Reza, did you mean to type something there? :)
03-20-2020 12:59 PM
Yes, Sorry. Not sure how that was even posted without me clicking on the "post" icon. :-)
03-20-2020 01:02 PM
Thanks!
Someone might want to look into revising that caveat in the HA guide, then. It's confusing IMHO.
03-20-2020 01:09 PM
Sure!
Sometimes Cisco documentations are not very clear or there is dependency between documents. I have seen a few where one document says one thing and the other one says something different. Usually, there are Cisco employees who post here and can take note so Cisco can address the issues.
Good luck with your project!
Reza
