01-11-2020 02:30 AM
dears
below is the link for datasheet, it mentioned that it has a perpetual and subscription licensing hence when i configure a switch in CCW i see subscription licensing only such as DNA essential, Advantage, premier , form where i can get the perpetual licensing option
01-11-2020 04:31 AM
01-11-2020 08:42 AM
Dear Leo
Thanks for the reply,
i didn't understood your reply, what i want to know is that if i want to optout DNA subscription and be on perpetual is it possible ??? but i don't see any optout option in the switch configuration tool ( CCW), Also would like to know that is it perpetual license is factory installed ??? becz i don't see any option to configure in the CCW
The only thing that is "perpetual" (aka permanent/lifetime) are the Essentials (aka base/basic) and Advantage (advanced).
Please elaborate more.
01-11-2020 08:55 AM
if you have not purchased DNA License, you no need to worry (as long as you are not added to BoM)
01-12-2020 03:29 AM
Dear Balaji
I cannot exit the BOM untill and unless i select the DNA subscription it mentioned the configuration is not correct, this is what i want to tell on this post,
how i can order the 9k family without DNA subscription and only with perpetual licenses ( essential or advantage)
