Catalyst macro description cisco-switch
opnineopnine
hi all,
I have to migrate a catalyst to a nexus 5000 and in some interfaces I have configured "macro description cisco-switch" and I was looking on the nexus docs but I cant find any thing about this?
Can any one help please?
Thanks.
I think Macros are not supported on Nexus instead there is port-profiles on Nexus.
Hello Madhukrishnan,
Thanks for the info, but I'm still a little bit lost, on the catalyst I have this config
interface GigabitEthernet1/0/14
 switchport mode trunk
 macro description cisco-switch ------??
 auto qos voip trust
 channel-group 4 mode desirable
 spanning-tree link-type point-to-point
How can I create a port-profile for the macro description cisco-switch?
Thanks!
Macros are not exactly similar to port-profile, i believe you can ignore that line of configuration if you are migrating and go ahead with the remaining configuration.
Thanks!
