Catalyst WC-3548XL-EN cyclic reboot during start
Grishazahid
Level 2
Level 2
Greetings!
I have found old switch at work and trying to reanimate it.
Catalyst WC-3548XL-EN goes into continious reboot, here is console logs:
Spoiler
C3500XL Boot Loader (C3500-HBOOT-M) Version 12.0(5.2)XU, MAINTENANCE INTERIM SOFTWARE
Compiled Mon 17-Jul-00 18:42 by ayounes
 starting...
Base ethernet MAC Address: 00:06:28:3c:b1:c0
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 16 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 3612672
flashfs[0]: Bytes used: 2919936
flashfs[0]: Bytes available: 692736
flashfs[0]: flashfs fsck took 4 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading "flash:c3500xl-c3h2s-mz.120-5.WC8.bin"...######################################################################################################################################################################################
File "flash:c3500xl-c3h2s-mz.120-5.WC8.bin" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 19-Jun-03 12:37 by antonino
Image text-base: 0x00003000, data-base: 0x0034E2F4
Initializing C3500XL flash...
flashfs[1]: 16 files, 2 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 3612672
flashfs[1]: Bytes used: 2919936
flashfs[1]: Bytes available: 692736
flashfs[1]: flashfs fsck took 4 seconds.
flashfs[1]: Initialization complete.
...done Initializing C3500XL flash.
C3500XL POST: System Board Test: Passed
C3500XL POST: Daughter Card Test: Passed
C3500XL POST: CPU Buffer Test: Passed
C3500XL POST: CPU Notify RAM Test: Passed
C3500XL POST: CPU Interface Test: Passed
C3500XL POST: Testing Switch Core: Passed
C3500XL POST: Testing Buffer Table: Passed
C3500XL POST: Data Buffer Test: Passed
C3500XL POST: Configuring Switch Parameters: Passed
Buffered messages:
Queued messages:
00:00:07: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:07: CPU Interface 0 SWITCH error in received packet on queue 3
And again the same
I tried to format flash memory and then copy firmware via xmodem. Firmware was downloaded from http://tfr.org/cisco-ios/catalysts/cat3500/ (this is the only founded source where these files are located, they are already EOL). But this procedure doesn't helps, errors remains the same. Do anyone have any ideas?
Georg Pauwen
to be blunt, I am afraid that your switch is toast. The error:
indicates a hardware failure, which used to be resolved by an RMA. Since the switch is EOL/EOS, you are out of options. Keep in mind that these models have been introduced about 20 years ago, and that is how old yours could be...
