Highlighted
Beginner
Catalyst WS-3850 model question
Hi guys, is there any model with all SFP 1G port within Catalyst 3850 series, similar with WS-C3750X-12S-E ....
Thank you !
5 REPLIES 5
Highlighted
Hall of Fame Expert
3850 series models are all copper.  If you need one with fiber interfaces, you would need to go 3750X, (as you already know).
Highlighted
Hall of Fame Guru
The best you can do on a 3850 is 4 x 1 Gbps SFPs in the optional C3850-NM-4-1G network module.
Besides the 3750X you mentioned, you could also move up to a 4500X which is all SFP-based. That's a much more capable switch though and will take you up a tier in price.
Highlighted
Beginner
Beginner
Highlighted
Hall of Fame Community Legend
The 3850-12S/24-S was released to the public a few days before Cisco Live SF 2014.
Please note that the modular uplinks are only 1 Gbps for the time being.  The 10 Gbps uplink will be made available by the end of 2014.
Also note that if you are going to use or add this model to an exhausting stack you need to factor in the minimum required software to support this model.
Highlighted
Vincent,
Please see https://www.cisco.com/c/dam/en/us/products/collateral/switches/catalyst-3850-series-switches/at-a-glance-c45-731636.pdf
Luke
Content for Community-Ad
