ccna question
jonk34567
Level 4
Level 4
question is attached below. what is the answer ?
No, this default gateway is not for InterVlan routing. Now Switch SVI VLAN 1 is working same as your system NIC. It should be aware, If It doesn't have routing information (except local subnet) then where the packet will send. So Default gateway is telling to switch is this is your default route.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
13 Replies 13
Deepak Kumar
The answer is D.
Deepak Kumar
Deepak Kumar,
if the default gateway is not assigned for host B then how it can ping A and C ?
Please read the answer. It is for the switch. The default gateway is not assigned to the switch.
Deepak Kumar
Deepak Kumar,
ok if switch is not assigned Default Gateway how host B can ping host A or C ?
yes. it is L2 device so if host A ( VLAN-1 ) needs to ping host B ( vlan 32 ) , the intervlan routing should occur in the router interface.so the packet needs to leave the switch. how can that happen without any default gateway assigned to switch ?
you are confused between switch's L2 mode and L3 mode. While a switch will in L2 mode, it will take packet forwarding decision based on the MAC Table and L3 mode is taking a decision on the routing table.
So in your case, When Host B (VLAN 32) sending a packet to the router and router forwarding this packet to Host A (VLAN 1). Now your switch is not aware of the source and destination IP address, It is having MAC address in the MAC table and sending a packet to Host A and vice versa based on your L2 header of the packet.
Now Switch is having manageable IP in VLAN 1 and you are trying to access from Host B (VLAN 32). Now router is forwarding packet to switch SVI and switch is not aware of the source IP address, which is in the packet and not aware of his gateway (L3) device. So packet dropped at the switch itself. (here, Switch MAC table will not be working because it should be replying to the l3 address).
Deepak Kumar
Deepak Kumar,
the question says
1.the host B can ping host A and host C
2.the host B can not telnet to Switch
your answer to resolve this issue is to configure default gateway in switch B.
so now my question is how intervlan routing can occur without a default gateway.
"so now my question is how intervlan routing can occur without a default gateway. "
As I mentioned that Inter VLAN routing is configured on the Router so all routing decision will take care of the router.
The switch is working as an L2 switch. It is responsible for L2 routing.
Deepak Kumar
Deepak Kumar,
for intervlan routing
  1. need to configure sub interfaces in router
Router(config)#int fa0/0.1
Router(config-subif)#encapsulation dot1q 10
Router(config-subif)#ip address 11.1.1.1 255.255.255.0
Router(config-subif)#no shut
2.need to assign ip address for vlan
switch(config)#int vlan 1
switch(config-vlan)#ip address 10.1.1.1 255.255.255.0
 3.configure ip default gateway on switch
  swi
switch(config)#ip default-gateway 11.1.1.1
 Are my 3 steps correct for intervlan configuration ? ( just the steps. i used random ip addresses )
Hi, It is better that you will assign the same VLAN (VLAN 1) gateway as your SVI address in the switch (VLAN 1).
Deepak Kumar
Deepak Kumar,
my question is do we need step-3( default gateway )  for inter-vlan routing ?
Deepak Kumar
Deepak Kumar,
yes i got it now. thank you very much for helping me to figure it out.
