CDP Problem
andresfaraque1
Hello.
I´m having a problem with mi LAN becase i´m seeing with CDP devices that are not connected directly:
Device A ------ SW CISCO A------ SW CISCO B
I´m seeing the Device A with CDP in my SW B.
SW CISCO A#show ver
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(55)SE11, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Wed 17-Aug-16 13:46 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01900000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(44)SE6, RELEASE SOFTWARE (fc1)
Any idea of what is my problem??
Thank you.
Andrés.
14 Replies 14
Hulk8647
you sure you're not stacking these?
can you provide the below
#sh cdp neigh detail
Sure.
File attached.
And no, i have no stack in my SW.
Andrés.
Georg Pauwen
is this a live or a simulated network ? Post the output of 'debug cdp packets' ...
Hello Georg, is a Live.
Debug Attached
Andrés.
Well, what is Device A? What is it's MAC address?
From Cisco A and B can you provide:
#show mac address-table
Hello Hulk8647
My devices are:
Switch A -> WS-C2960-48TC-L
Switch B ->  WS-C6506-E
File attached.
Andrés.
I tried to disable CDP in one port and this is the  result:
SWITCH A#show cdp nei fastEthernet 0/19
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
CVTA             Fas 0/19          147               H    Associate Port 2
SEP8851FB82428D  Fas 0/19          86               H P   Communica Eth 11
In SWITCH A i disable de CDP:
interface FastEthernet0/19
 no cdp enable
cosabog13l2715#show cdp nei FastEthernet0/19
But in my SWITCH B, i´m still receiving the CDP of the Device that is connected to the Port 19 in SWITCH A.
COSABOG13SWL301#show cdp nei GigabitEthernet3/7 | i 428D
SEP8851FB82428D  Gig 3/7           164              H P   Communica Eth 11
did you clear your CDP on the switch B after disabling CDP? I believe the default timeout for CDP is 180 seconds. If its still disabled and you haven't enabled it, I would check now. Or, you can use "clea cdp table"
Yes, I clear the table in Switch B when I disable the CDP in Switch A
SWITCH B#clear cdp  table
SWITCH B#clear cdp  counters
SWITCH B#show cdp nei gi 3/7
CVTA             Gig 3/7           179               H    Associate Port 1
CVTA             Gig 3/7           179               H    Associate Port 2
A couple of seconds later...
SWITCH A      Gig 3/7           175              S I   WS-C2960- Gig 0/2
SEPD4C9EFDEBFD8  Gig 3/7           158              H P   Communica Eth 11
SEP8851FB82428D  Gig 3/7           145              H P   Communica Eth 11  -------> Port Fa0/19 in SWITCH A
SEP40A8F0A3EDBD  Gig 3/7           115              H P   Communica Eth 10
SEPD4C9EFD4AEDD  Gig 3/7           157              H P   Communica Eth 17
SEPD4C9EFD62A1C  Gig 3/7           168              H P   Communica Eth 11
SEP40A8F0A3EDE9  Gig 3/7           157              H P   Communica Eth 10
SEP40A8F0A3F295  Gig 3/7           145              H P   Communica Eth 10
SEP40A8F0A4C164  Gig 3/7           155              H P   Communica Eth 11
SEPD4C9EFD4AFD0  Gig 3/7           157              H P   Communica Eth 11
SEP40A8F0A431C4  Gig 3/7           157              H P   Communica Eth 10
SEPD4C9EFD4AE3E  Gig 3/7           143              H P   Communica Eth 11
SEPD4C9EFD6A310  Gig 3/7           158              H P   Communica Eth 18
But in my Switch A CDP don´t show nothing...
SWITCH A#show cdp nei fa 0/19
SWITCH A#
Andrés.
you have physically verified the cabling between these switches ?
Yes, is Fiber
NAME: "GigabitEthernet0/2", DESCR: "1000BaseSX SFP"
Andrés.
could you provide show run of both switches ?
This link doesn't specifically answer you question, but you may find it useful for some of the findings you have come across during the troubleshooting steps.
https://supportforums.cisco.com/t5/lan-switching-and-routing/cdp-neighbours/td-p/2485786
Hello Cofee.
Thank you, but is not my case, all my SW are cisco.
Hulk8647:
File attached with the config
Andrés.
