Change VTP mode from Client to Transparent
ogormam2
Hi I am planning to change all my swithches to transparent mode.
On my clients i will issue "vtp mode transparent" and "vtp domain switchname"
i just want to make sure this is ok, the clients currently get their vlans form the VTP server, if i do a "sh run" i cant see the vlans configured, they are stored in the VLAN.dat file.
When i issue the VTP mode transparent command will the vlans be copied to the running config?
thanks for any help
glen.grant
Yes when you change to transparent it will show up in the running config usually up towards the top of the config file.
glen.grant
thank you
