Changing a Nexus switch in cluster
AmdouniMohamed
I want to perfurm a change for a Nexus switch "cisco Nexus 56128P Chassis" with "cisco Nexus5548 Chassis" without getting a production down on the cluster, can I perfurm w backup/restore to the config ?
those switch will be able to work together in cluster without getting a problem in our VSAN ?
for the firmware and the software there is any problem to put them together in the same cluster ?
I'm wainting for your helps and advice
thanks a lot
nazimkha
As far I can understand you want to swap Nexus 5548 with Nexus 56128.
Migration from one switch to the other with zero downtime may not be possible.
if you can share the network topology, can suggest an optimal way to do the changeover
